Site time
Site time
#1 Post by richb »
For those of you in areas using Daylight Savings Time, please adjust the Board Time to Standard time. This is done from your user Control Panel>Board Preferences.
EDIT: If the Forum time matches your local time there is nothing to do.
tascoast
Re: Site time
#2 Post by tascoast »
You've got me here, on the standard time part. Australia has several time zones and Tasmania jumps into Daylight Savings first I believe, given the latitude.
The attached reads as the correct time locally for me. So this post comes shortly after the captured image, at 9:47am.
tascoast
Re: Site time
#3 Post by tascoast »
The above post also displays the correct post time for me, locally.
Re: Site time
#4 Post by richb »
If you board time matches your correct local time, nothing to do.
Standard Time is the designation The USA uses vs. Daylight Savings Time.
https://www.timeanddate.com/time/standard-time.html
tascoast
Re: Site time
#5 Post by tascoast »
http://www.australia.gov.au/about-austr ... ght-saving
Radio broadcasters have fun here trying to reconcile the various state and territory time calls. Thanks kindly
Mick
Re: Site time
#6 Post by richb »
We have it easy by comparison. :confused:
Gaer Boy
Re: Site time
#7 Post by Gaer Boy »
Rich - your original post is correct for the Northern Hemisphere - south of the Equator, the switch is the opposite way.
Re: Site time
#8 Post by richb »
Gaer Boy wrote:Rich - your original post is correct for the Northern Hemisphere - south of the Equator, the switch is the opposite way.
OK How about:
For those of you in areas using Daylight Savings Time, please adjust the Board Time to match your local time. This is done from your user Control Panel>Board Preferences.
antiX-Dave
Re: Site time
#9 Post by antiX-Dave »
Where is the clock on the forum? How do I know what is the right time and what does he wrong time do?
Last time I looked at the forum code it writes machine date in the database and translates that when displayed.
Gordon Cooper
Re: Site time
#10 Post by Gordon Cooper »
Nonsense. It is exactly the same. Plus, what you see as Forum Time differs depending upon whether you have logged in or not.
Return to “Site Help”
