"Remember Login" password not saving?
Richard
#1 Post by Richard »
I've noticed in the last few days that I must login every day.
Has something changed with the Login function?
I check Save or Remember but it doesn't.
Anyone else seeing this?
It doesn't survive a reboot.
Richard
Re: Remember Login password not saving?
#2 Post by Richard »
Well, apparently no one else has this problem
of being forced to sign in to the forum every day.
Must be just me.
#3 Post by Jerry3904 »
It looks like it. Can you post the contents of /etc/lightdm/lightdm.conf.
Richard
#4 Post by Richard »
Thanks. Hopefully it is something I did.
Contents of /etc/lightdm/lightdm.conf
# General configuration
# start-default-seat = True to always start one seat if none are defined in the configuration
# greeter-user = User to run greeter as
# minimum-display-number = Minimum display number to use for X servers
# minimum-vt = First VT to run displays on
# lock-memory = True to prevent memory from being paged to disk
# user-authority-in-system-dir = True if session authority should be in the system location
# guest-account-script = Script to be run to setup guest account
# log-directory = Directory to log information to
# run-directory = Directory to put running state in
# cache-directory = Directory to cache to
# xsessions-directory = Directory to find X sessions
# remote-sessions-directory = Directory to find remote sessions
# xgreeters-directory = Directory to find X greeters
# disable-guest-wrapper = Disable using guest session wrapper (temporary? required to make tests work without installing)
[LightDM]
#start-default-seat=true
#greeter-user=lightdm
#minimum-display-number=0
#minimum-vt=7
#lock-memory=true
#user-authority-in-system-dir=false
#guest-account-script=guest-account
#log-directory=/var/log/lightdm
#run-directory=/var/run/lightdm
#cache-directory=/var/cache/lightdm
#xsessions-directory=/usr/share/xsessions
#remote-sessions-directory=/usr/share/lightdm/remote-sessions
#xgreeters-directory=/usr/share/xgreeters
#disable-guest-wrapper=false
# Seat defaults
# type = Seat type (xlocal, xremote)
# xserver-command = X -dpi $DPI server command to run (can also contain arguments e.g. X -special-option)
# xserver-layout = Layout to pass to X server
# xserver-config = Config file to pass to X server
# xserver-allow-tcp = True if TCP/IP connections are allowed to this X server
# xdmcp-manager = XDMCP manager to connect to (implies xserver-allow-tcp=true)
# xdmcp-port = XDMCP UDP/IP port to communicate on
# xdmcp-key = Authentication key to use for XDM-AUTHENTICATION-1 (stored in keys.conf)
# greeter-session = Session to load for greeter
# greeter-hide-users = True to hide the user list
# greeter-allow-guest = True if the greeter should show a guest login option
# greeter-show-manual-login = True if the greeter should offer a manual login option
# greeter-show-remote-login = True if the greeter should offer a remote login option
# user-session = Session to load for users
# allow-guest = True if guest login is allowed
# guest-session = Session to load for guests (overrides user-session)
# session-wrapper = Wrapper script to run session with
# display-setup-script = Script to run when starting a greeter session (runs as root)
# greeter-setup-script = Script to run when starting a greeter (runs as root)
# session-setup-script = Script to run when starting a user session (runs as root)
# session-cleanup-script = Script to run when quitting a user session (runs as root)
# autologin-guest = True to log in as guest by default
# autologin-user = User to log in with by default (overrides autologin-guest)
# autologin-user-timeout = Number of seconds to wait before loading default user
# autologin-session = Session to load for automatic login (overrides user-session)
# exit-on-failure = True if the daemon should exit if this seat fails
[SeatDefaults]
#type=xlocal
xserver-command=X -dpi $DPI
#xserver-layout=
#xserver-config=
xserver-allow-tcp=false
#xdmcp-manager=
#xdmcp-port=177
#xdmcp-key=
greeter-session=lightdm-greeter
#greeter-hide-users=true
#greeter-allow-guest=true
#greeter-show-manual-login=false
#greeter-show-remote-login=true
#user-session=default
#allow-guest=true
#guest-session=UNIMPLEMENTED
session-wrapper=/etc/X11/Xsession
display-setup-script=/usr/local/bin/early-bg
#greeter-setup-script=
#session-setup-script=
#session-cleanup-script=
#autologin-guest=false
autologin-user=richard
autologin-user-timeout=0
#autologin-session=UNIMPLEMENTED
#exit-on-failure=false
# Seat configuration
# Each seat must start with "Seat:".
# Uses settings from [SeatDefaults], any of these can be overriden by setting them in this section.
#[Seat:0]
# XDMCP Server configuration
# enabled = True if XDMCP connections should be allowed
# port = UDP/IP port to listen for connections on
# key = Authentication key to use for XDM-AUTHENTICATION-1 or blank to not use authentication (stored in keys.conf)
# The authentication key is a 56 bit DES key specified in hex as 0xnnnnnnnnnnnnnn.  Alternatively
# it can be a word and the first 7 characters are used as the key.
[XDMCPServer]
#enabled=false
#port=177
#key=
# VNC Server configuration
# enabled = True if VNC connections should be allowed
# command = Command to run Xvnc server with
# port = TCP/IP port to listen for connections on
# width = Width of display to use
# height = Height of display to use
# depth = Color depth of display to use
[VNCServer]
#enabled=false
#command=Xvnc
#port=5900
#width=1024
#height=768
#depth=8
#5 Post by richb »
Jerry3904 wrote:It looks like it. Can you post the contents of /etc/lightdm/lightdm.conf.
Does lightdm have any connection with Forum login? I always have needed to login to the forum. There was no intentional change.
EDIT: Nevermind. Misread the OP's post.
Re: Remember Login password not saving? [Resolved]
#6 Post by Jerry3904 »
@Richard: is this resolved?
Richard
#7 Post by Richard »
No it isn't. I just thought it was only my problem.
Apologies Jerry, didn't mean to cut you off.
I thought it was just the way it is setup.
Didn't used to act this way.
I think it is a problem with either Slimjet or my configuration of the forum.
There is a page on managing Remember Login,
http://forum.mepiscommunity.org/ucp.php ... login_keys
but I really think it is Slimjet but could be wrong.
At any rate, login to forum, check remember me,
close slimjet, open slimjet and still logged in.
Reboot and the forum doesn't remember me?
Repeated this sequence with same result.
I suppose I need to create a shorter password. :)
#8 Post by Jerry3904 »
My fault, didn't realize this post was in Site Help
Richard
#9 Post by Richard »
I really don't know what happened, but running Firefox ESR and everything works as exected?
Perhaps the integration with Chrome-Google is broken a bit in Slimjet.
Maybe it's just time to go back to Firefox. :)
Thanks for the tips.
I looked through the LightDM.donf but haven't noticed anything that might cause my login problem.
@Jerry3904, did you see anything or have any ideas?
#10 Post by Jerry3904 »
It looked normal to me when I scanned through it this morning.
Return to “Site Help”
