bookmarked threads?
bookmarked threads?
#1 Post by Adrian »
I see there's a way to bookmark thread where can I find the threads that I bookmarked?
I'm particularly interested in this use-case: I see the new posts, I then bookmark or pin a thread and then click "mark all as read". I should be able to go back easily to see the bookmarked/pinned threads. How to do that?
Gordon Cooper
Re: bookmarked threads?
#2 Post by Gordon Cooper »
Maybe I am approaching this from a different angle. Am using Pale Moon Browser where I can right click (secondary click) on any Forum thread, select Bookmark Link and save the link in the bookmarks file. Then next time the browser is opened, Click on the bookmarks Tab and chose the desired link. goes straight to the saved thread regardless of the read status. Only 'con' looks to be the need to clear out the bookmarks file on occasions.
tascoast
#3 Post by tascoast »
http://forum.mepiscommunity.org/ucp.php ... =bookmarks
Via control panel here, although I've none myself to check
Inspiron 15 5000-5593- (i7-1065G7) MX 19.2 AHS/MX-21//W10 - Lenovo ThinkCentre A58 4GBRAM (64-bit), MX-21/MX19/antiX19/Mint 19
tascoast
#4 Post by tascoast »
But I have bookmarked (In Firefox) the forum user bookmarks now for easy reference.
#5 Post by Adrian »
I don't really want to bookmark pages in my browser, I've found the bookmarked threads in the Control Panel -> Profile -> Manage bookmarks, but that's way too many clicks, it would be nice to have that in "Quick links"
Gordon Cooper
#6 Post by Gordon Cooper »
Had quick browse thru' the forum's database documentation but did not find anything helpful.
Return to “Site Help”
